Using emonPi Offline: How to setup a WIFI Hotspot on an emonPi
The guide is based on Dave Conroy's guide here but also covers setting up a DHCP server rather than ethernet to WIFI bridge.
There are 3 pieces of software that need to be installed to get this to work:
- hostapd – WIFI Hotspot
- edimax version of hostapd
- isc-dhcp-server – DHCP Server
sudo apt-get install isc-dhcp-server
2) Install Edimax version of hostapd
Either use precompiled binary or compile yourself:
Pre-compiled (update: does not seem to work with wheezy, use self compile see below)
wget http://www.daveconroy.com/wp3/wp-content/uploads/2013/07/hostapd.zip
unzip hostapd.zip
sudo mv /usr/sbin/hostapd /usr/sbin/hostapd.bak
sudo mv hostapd /usr/sbin/hostapd.edimax
sudo ln -sf /usr/sbin/hostapd.edimax /usr/sbin/hostapd
sudo chown root.root /usr/sbin/hostapd
sudo chmod 755 /usr/sbin/hostapd
Compile yourself (recommended for wheezy, tested March16)
sudo apt-get install libnl-genl-3-dev libnl-3-dev
git clone https://github.com/lostincynicism/hostapd-rtl8188
cd hostapd-rtl8188/hostapd
sudo make
sudo make install
3) Configure /etc/network/interfaces
Open the network interfaces file to edit:
sudo nano /etc/network/interfaces
Replace content with:
auto lo
iface lo inet loopback
auto eth0
allow-hotplug eth0
iface eth0 inet manual
#allow-hotplug wlan0
#iface wlan0 inet manual
# wpa-conf /etc/wpa_supplicant/wpa_supplicant.conf
iface wlan0 inet static
address 192.168.42.1
netmask 255.255.255.0
allow-hotplug eth1
iface eth1 inet dhcp
If required add bridge to bridge eth0 to wlan0 - although it's better to use NAT iptables forwarding since then we can still access pi via ssh (see below)
auto br0
iface br0 inet dhcp
bridge_ports eth0 wlan0
pre-up ifconfig eth0 0.0.0.0 up
pre-up ifconfig wlan0 0.0.0.0 up
pre-up brctl addbr br0
pre-up brctl addif br0 eth0
post-down ifconfig wlan0 0.0.0.0 down
post-down ifconfig eth0 0.0.0.0 down
post-down brctl delif br0 eth0
post-down brctl delbr br0
4) Configure /etc/hostapd/hostapd.conf
Open hostapd config file with:
sudo nano /etc/hostapd/hostapd.conf
Add the following lines to hostapd.conf (set SSID and password of your choice)
WITHOUT AUTHENTICATION USE
interface=wlan0
ssid=emonPi
driver=rtl871xdrv
hw_mode=g
channel=6
auth_algs=1
wmm_enabled=0
WITH_AUTENTICATION USE
interface=wlan0
driver=rtl871xdrv
ssid=emonPi
hw_mode=g
channel=6
macaddr_acl=0
wmm_enabled=0
auth_algs=1
ignore_broadcast_ssid=0
wpa=2
wpa_passphrase=raspberry
wpa_key_mgmt=WPA-PSK
wpa_pairwise=TKIP
rsn_pairwise=CCMP
Manual start to test everything is working, you should see a Wifi network called 'emonPi':
$ sudo hostapd -dd /etc/hostapd/hostapd.conf
5) Configure /etc/default/hostapd
sudo nano /etc/default/hostapd
Set
DAEMON_CONF="/etc/hostapd/hostapd.conf"
6) Configure /etc/dhcp/dhcpd.conf
Open dhcpd config file:
sudo nano /etc/dhcp/dhcpd.conf
Add the following to the end of the file:
lease-file-name "/home/pi/data/dhcpd.leases";
subnet 192.168.42.0 netmask 255.255.255.0 {
range 192.168.42.2 192.168.42.20;
option broadcast-address 192.168.42.255;
option routers 192.168.42.1;
default-lease-time 600;
max-lease-time 7200;
option domain-name "local";
option domain-name-servers 8.8.8.8, 8.8.4.4;
comment out #option domain-name "example.org";
#option domain-name-servers ns1.example.org, ns2.example.org;
uncomment
authoritative;
7) Configure /etc/default/isc-dhcp-server
sudo nano /etc/default/isc-dhcp-server
Remove the comment from DHCPD_CONF, DHCPD_PID and then set the INTERFACES to "wlan0" (including ""), see example below:
# Defaults for isc-dhcp-server initscript
# sourced by /etc/init.d/isc-dhcp-server
# installed at /etc/default/isc-dhcp-server by the maintainer scripts
# This is a POSIX shell fragment
# Path to dhcpd's config file (default: /etc/dhcp/dhcpd.conf).
DHCPD_CONF=/etc/dhcp/dhcpd.conf
# Path to dhcpd's PID file (default: /var/run/dhcpd.pid).
DHCPD_PID=/var/run/dhcpd.pid
# Additional options to start dhcpd with.
# Don't use options -cf or -pf here; use DHCPD_CONF/ DHCPD_PID instead
#OPTIONS=""
# On what interfaces should the DHCP server (dhcpd) serve DHCP requests?
# Separate multiple interfaces with spaces, e.g. "eth0 eth1".
INTERFACES="wlan0"
8.) Setup NAT forwarding to bridge eth0 the wlan0 while still allowing us to access the Pi via SSH (pure network bridge does not)
To set this up automatically on boot, edit the file /etc/sysctl.conf and add the following line to the bottom of the file:
net.ipv4.ip_forward=1
Second, to enable NAT in the kernel, run the following commands:
sudo iptables -t nat -A POSTROUTING -o eth0 -j MASQUERADE
sudo iptables -A FORWARD -i eth0 -o wlan0 -m state --state RELATED,ESTABLISHED -j ACCEPT
sudo iptables -A FORWARD -i wlan0 -o eth0 -j ACCEPT
If bride is also required to eth1 (for 3G dongle) add:
sudo iptables -t nat -A POSTROUTING -o eth1 -j MASQUERADE
sudo iptables -A FORWARD -i eth1 -o wlan0 -m state --state RELATED,ESTABLISHED -j ACCEPT
sudo iptables -A FORWARD -i wlan0 -o eth1 -j ACCEPT
sudo sh -c "iptables-save > /etc/iptables.ipv4.nat"
Now edit the file /etc/network/interfaces and add the following line to the bottom of the file:
up iptables-restore < /etc/iptables.ipv4.nat # This did not work for me I had to add entry to rc.local (see below)
8) Edit /etc/rc.local
sudo nano /etc/rc.local
Add before exit 0 the following lines to tell the wlan interface to use ip address 10.0.1.1 and then start the isc-dhcp-server:
sudo iptables-restore < /etc/iptables.ipv4.nat
sudo ifconfig wlan0 192.168.42.1
sudo service isc-dhcp-server restart
9) Start services at boot
sudo update-rc.d isc-dhcp-server defaults
sudo update-rc.d hostapd defaults
Thats it restart your emonpi/emonbase to finish and then connect to network emonPi with password: raspberry
11) Add a Real Time Clock (RTC)
When running an emonPi in offline mode we recommend adding a hardware RTC to ensure the system time is always correct. See emonPi Wiki:
Resources
Useful blogs, guides and forum threads that I used to work out how to set up the above:
http://www.daveconroy.com/turn-your-raspberry-pi-into-a-wifi-hotspot-with-edimax-nano-usb-ew-7811un-rtl8188cus-chipset
http://askubuntu.com/questions/140126/how-do-i-configure-a-dhcp-server
http://ubuntuforums.org/showthread.php?t=2068111
http://raspberrypi.stackexchange.com/questions/9678/static-ip-failing-for-wlan0
https://forums.opensuse.org/showthread.php/438756-DHCP-can-t-write-to-dhcpd-leases
http://elinux.org/RPI-Wireless-Hotspot
http://www.instructables.com/id/Raspberry-Pi-as-a-3g-Huawei-E303-wireless-Edima/?ALLSTEPS
| Hardware RTC |
Resources
