Hourly energy model example 4: Complementarity of different renewable generating technologies
How do we work out the best mix of different renewable generating technologies. When is it cheaper to add more wind than to add more solar, what is the balance point for a particular demand profile?
This example explore's the balance point for onshore wind + solar, both having large resource availabilities associated with them. The mix will be balanced based on energy cost. It would also be good to explore the balance based on embodied energy. As with all modelling based on costs the outcome will change as costs change, the important thing here is to understand the method so that we can explore for a given set of costs what the optimum mix might be.
In the recent contracts for a difference auction in the UK for renewable generation many of the onshore wind farms received a strike price of £82.50 per MWh. Two offshore wind projects received £115 per MWh and three solar farms received £79.23 per MWh.
Source: Contracts for Difference Auction Results
In this example we will use these cost figures, the ZCB capacity dataset for onshore wind and solar and a simple flat demand profile.
If we look at the results from example 2 investigating annual matching for wind and solar and add in the cost information:
- 1.164kW of onshore wind delivers 3300 kWh/y at £272/y and a supply/demand matching of 65.88%.
- 3.99kW of solar delivers 3300 kWh/y at £261/y and a supply/demand matching of 40.61%.
So lets take an annual energy cost of £272 and work out for this cost what is the maximum level of matching we can obtain from a wind + solar mix.
Online tool: http://openenergymonitor.org/energymodel > navigate to 4. Mixed supply and flat demand
| Cost | Wind capacity | Solar capacity | Matching |
| £272.02 | 1.1635 | 0 | 65.86 % |
| £272.03 | 1.0235 | 0.5 | 70.04 % |
| £272.03 | 0.9395 | 0.8 | 71.22 % |
| £272.03 | 0.9115 | 0.9 | 71.33% |
| £272.04 | 0.8975 | 0.95 | 71.35% |
| £272.04 | 0.8835 | 1.0 | 71.34 % |
| £272.04 | 0.8695 | 1.05 | 71.31 % |
| £272.04 | 0.8555 | 1.1 | 71.26 % |
| £272.04 | 0.8275 | 1.2 | 71.09% |
At an energy cost of £272/year a flat demand and the ZCB dataset we can see a clear benefit from combining solar and wind in the energy mix, increasing solar pv capacity appears to make sense up to 105.8% of installed wind capacity after which the matching starts to drop again for the given energy cost.
Its important to note however that wind still provides the majority of the electricity at 2543 kWh of the 3300 kWh generated annually (76%). This is because of wind's higher capacity factor in comparison with solar.
How does the mix change if we decide to oversupply and pay a higher cost for the electricity. If we fix our annual cost to say £320
| £320.06 | 1.369 | 0 | 69.88 % |
| £320.07 | 1.229 | 0.5 | 73.98 % |
| £320.08 | 1.144 | 0.8 | 75.20 % |
| £320.08 | 1.089 | 1.0 | 75.44 % |
| £320.08 | 1.075 | 1.05 | 75.45 % |
| £320.08 | 1.061 | 1.1 | 75.44 % |
| £320.08 | 1.047 | 1.15 | 75.41 % |
| £320.08 | 1.033 | 1.2 | 75.37 % |
The maximum matching we obtained in this case happened where solar capacity was 97.7% of wind capacity.
It appears that in these model runs, the optimal mix between solar and wind is to install an equal capacity of both, its interesting that this happens to be the case and that its not say half the wind capacity. The model results confirm the often discussed complementarity between solar and wind supply and that the benefit of their combination increases supply demand matching by around 5% points for no additional cost and is a similar scale of supply/demand matching improvement seen by increasing the oversupply of wind to 120% of demand but without the additional cost.
Download python model:
http://openenergymonitor.org/energymodel/python/windandsun.py To engage in discussion regarding this post, please post on our Community Forum.
