Load stat's for MYISAM vs INNODB for feed storage on the RaspberryPI
First using the INNODB storage engine:
A load of 3.5 causes an issue where the time that is recorded for data packets coming in gets messed up creating bunched up datapoints:
Switching the storage engine over the MYISAM, reduced the load to around 0.2 and the timing issue is no longer present:
To convert your raspberry pi emoncms Innodb tables to MYISAM you can run the following script on your raspberrypi which will go through each table converting them in turn:
$mysqli = new mysqli("localhost","root","raspberry","emoncms");
$result = $mysqli->query("SHOW tables");
while ($row = $result->fetch_array())
echo "ALTER TABLE `".$row[0]."` ENGINE=MYISAM\n";
$mysqli->query("ALTER TABLE `".$row[0]."` ENGINE=MYISAM");
