Carbon Coop
| http://carbon.coop |
They want monitoring to be at the centre of everything they do, so that their members can see how minor changes impact energy usage as well as more major retrofit changes. They also want to monitor internal air quality as well as temperature for early identification of any problems with the insulation and airtightness measures. By monitoring humidity, CO2 as well as temperature Matt explained that its possible to isolate issues around damp/cooking etc from issues around ventilation.
They are really keen to use open source technology because that then gives them the freedom to configure the system as they need and then get at the data. They are keen advocates for open data and open source software and hardware in general and carry out their own work in an open way.
Since then Carbon Coop have installed 18 openenergymonitor energy monitors in houses across Manchester, held two energy monitor workshops including last weekends and are going forward with retrofitting 15 houses to between 60 and 80% carbon reduction.
| Building monitors at the Carbon Coop EcoHomeLab workshop 19th-20th April |
Every-time I go to visit them I come back inspired to develop things further. One of the highlights of the last visit was listening to Eleni Kalkantzi who works for URBED (Carbon Coop's technical partner) talk about the whole house assessment methodology and reports she, Charlie Baker and Marianne Heaslip have developed. A huge amount of work has clearly gone into these reports and the assessment method, they have an example report and report on the assessment method here:
See their example assessment here: http://carbon.coop/assessments/CC_EXAMPLE_ASSESSMENT2.pdf
Report on the assessment method: http://carbon.coop/assessments/URBED_ASSESSMENT_REPORT.pdf
They see the next step being to integrate monitoring data directly in to the SAP model on which their reporting is based to reduce the number of assumptions made. This is where the open source emoncms SAP model that we have been developing comes in but I will come back to that in another post.
