A start on DC current sensing
The wind turbine creates 12V DC electricity. It can produce up to around 500W of power, about 40Amps.
I have decided to go along the invasive current sensing route with a sense resistor (also known as a shunt). When dealing with such high currents the sense resistor needs to be quite beefy! Here's a picture of my test setup using a computer power supply to simulate the wind turbine and a 50W halogen as a load. The large block in the middle is the sense resistor.
I came across quite a lot of good circuit examples and advice on the linear technologies website here. Im thinking of following the battery current monitor circuit which can be found in their DC pdf. Here's the schematic:
It can measure both current flowing in to the battery when the wind turbine is generating and current flowing out of the battery when there are loads connected.I will post up the results once its built, I also need to make a load that can vary between 0 and 500W so it can be tested properly, the current plan is to make that load from a mini 12V kettle and a mixture of 50W 20W and 10W halogen bulbs all of which can be turned on and off from the Arduino. Should be fun!
If anyone has any experience with renewables and DC current measuring circuits I would be glad of any suggestions on any of the above. To engage in discussion regarding this post, please post on our Community Forum.
